- South Manchester
Oh and it looks good, PVC edging is better than MDF for cleaning, and MrsF is very happy. Win win.
Major mission of an ensuite is now complete barr a few minor bits.
That's the hot tub pump repaired (yes I know, I know). We bought an inflatable one years ago, and it sits in it's own walled gazebo in the garden so it quite protected. During the warranty, the 'blower' failed. So we were sent a whole new unit (heater/pump/blower). It's been used for spares, like a replacement impeller when it wore out etc.
This time the pump went - I initially thought the impeller had gone, but upon inspection, the pump unit had split allowing water ingress.
Dug out the old 'unit' from the garage loft and the original pump was re-purposed. Cost of the job zero. Saved £60 from getting a refurbished pump off ebay.
If the pumps housing? split, it's likely designed to do so, in which case it may repeat with the other pump, so it might be an idea to reinforce it somehow.
For ex, clothes racks, plastic (corner) connections of steel tubes, steel tubes end shifts under some pressure inside plastic, but plastic is made too thin and after a while it splits open. So, I decided to strap some layers of tape around all these plastic connections, and since, no further splits anymore.
Bath waste is slow to drain..
I replaced the waste so it's the pipe.
Someone has boxed in the pipe and tiled over it!😭
Get some piano wire, shove it down the pipe and spin it on a drill or use compressed air to dislodge the blockage
