Chris S
- Birmingham
How do you know when a single-speed chain needs replacing? Will there be an adverse effect on performance?
If the bike has a chain tensioner then worn chains need much more work from it. My bike gets noisier as the chain wears. It is nice and quiet with a new chain, when the tensioner barely touches the chain...How do you know when a single-speed chain needs replacing? Will there be an adverse effect on performance?
Thanks. My bike has a 3-speed hub gear but a worn chain would have the same consequences. I haven't got a gauge so I'll just replace the chain when it starts coming off.If the bike has a chain tensioner then worn chains need much more work from it. My bike gets noisier as the chain wears. It is nice and quiet with a new chain, when the tensioner barely touches the chain...
This is what it looks like with a slacker worn chain...
It doesn't really make it harder to ride though!
If you didn't take up enough slack then there would be more chance of the chain coming off.
PS Yes, there ARE 2 sprockets but the smaller one is only there for the lockring to bite against! I used to tighten the ring directly against a stack of spacers but it came loose on a couple of rides.
This is the pragmatic option given you are replacing a relatively cheap sprocket and not an expensive 11spd cassette. That was pretty much my approach on the brompton (3spd), which is effective a single speed for the purpose of this discussion.If you are happy to replace the sprocket each time, you can more or less run them both into the ground. It takes a lot to wear out the (expensive) chainring.
