r04DiE
300km a week through London on a road bike.
No. Why?Is this another wind-up?
No. Why?
...front and rear works quite nicely for me as I do like a hard ride....
It's new information to me so perhaps I should apologise for my ignorance.Because a smaller contact patch does not necessarily equal less rolling resistance. There's so much more to it than that. In many cases, a tyre with lower pressure will roll better than the same tyre at a higher pressure. This is not new information, by the way.
Have you any data to back that up?
Data to back it up? I thought it was common knowledge. All things being equal, on a smooth surface, a tyre will roll better at high pressure. Which is why trackies tend to go for high pressures (ie 120+) and (conversely) why P-R riders tend to go for wider tyres at lower pressures. On a 'real world' road surface, with all its various imperfections, a lower pressure will allow the casing to deflect more, thereby enabling the tyre to absorb road shocks, rather than bounce over them. Bouncing obviously diverts the wheel upwards, rather than forwards.
A quick scan through google should be all you need.
That was not what you said though , you said
"a tyre with lower pressure will roll better than the same tyre at a higher pressure"
Which is incorrect !
Well where is your evidence to support that this is true then? i.e. that it is commonly the case?... "In many cases"...
Except I preceded that statement with the phrase "In many cases" - maybe you forgot to read that bit?
and @r04DiEHave you any data to back that up? , all the data I have saw says the opposite!
I already named one example - Paris/Roubaix. Maybe you missed that as well.Could you name one case ?![]()
This article gives some useful arguments (if not data) on which @S-Express may be drawing
