S-Express
The problem is that modern carbon frames (and forks) are so compliant and rigid
How can a material be both 'compliant' and 'rigid'..??
One of the lads thought he heard the sound of carbon cracking.
You must be new here.
I dunno - the failure of aluminium is much more sudden than steel. Maybe I'll stay with that.Anyone who is paranoid about every little knock or scratch on a carbon frame really ought to stick to aluminium or steel. They'll sleep better.
The Titanic was made of steel. Just sayin'.Aluminium bikes are liable to explode without warning. Google thermite.
Steel is the only safe solution.
What were the weather conditions like when the bike was crashed? If it was wet then I'd be very careful with the frame.
Carbon components are precision engineered for compliance and rigidity. The problem is that modern carbon frames (and forks) are so compliant and rigid that external factors such as rain interference combine with the carbon layup to deliver unexpected lateral forces on the material. Therefore, if it was raining at the time of the crash there is a heightened risk of damage.
Considering all of this, I'd agree with @fossyant - the bike must be replaced. Some parts may be salvageable though, so I'll give you £50 for it!
Seriously though - if you've lost confidence in the component, then either get it checked by someone you trust and knows what they are doing, or get rid of it. If you're anything like me, then a niggling doubt in your mind will play games with you, particularly on descents! I might be inclined to use such an incident as a ride to upgrade city!![]()
I'll watch out for icebergs.....The Titanic was made of steel. Just sayin'.
What about raging internal fire?I'll watch out for icebergs.....
You're right, I do need to rein in my temper a bitWhat about raging internal fire?
Are you possession of that material?Wood is the only safe frame material.
