Old Plodder
Living at the top of a steep 2 mile climb
- Surrey/Hants border
Axle locators; chain tugs normally fit onto the axle or the dropout to pull the chain into tension.
Axle locators; chain tugs normally fit onto the axle or the dropout to pull the chain into tension.![]()
I have put my camera on charge in readinesswith a few quid I had left over from my c2w voucher have asked them to fit a fixed cog and lockring to the other side of the hub![]()
You'll probably be my guinea pigI have put my camera on charge in readiness
Mudguards? Rack? On that bike?
Not suitable.
Yeh, but you'll be endlessley adjusting the guards to stop 'em rubbing, and the rack won't have capacity for any known pannier configuration.I have guards and a rack on my flier.
Yes and no, on the face of it a road bike would not be your first choice to tour on, however plenty of folk have done just that, in fact one guy [I forget his name] went round the world with all his gear on a road bike. Obviously you are unlikely to tour on a fixed unless it is the Netherlands. Different tyre makes come up in different sizes, for instance a 700 x 25 Gatorskin is much bigger than a 700 x 28 Schwalbe Durano, I know because I toured on the latter and my fixed came with the former, which I quickly changed. Tinkering with a bike is half the fun, though quite why some bikes are now produced with such tight fork / bridge clearances I have no idea, a few millimetres more would hardly disadvantage the bike in aero terms and aesthetically you would be hard put to see a difference.Yeh, but you'll be endlessley adjusting the guards to stop 'em rubbing, and the rack won't have capacity for any known pannier configuration.
It's not a touring bike.
You said;
I just need to set it up and sort out the carrier, the one I brought doesn't fit, too tall and the arm fouls the back brake, front mudguard went on straight away no problems, the back didn't fit, turns out there's not enough room under the brake bridge for a 700cx28 tyre and my mudguard.
Not suitable for mudguards or rack. It's not a touring bike.
You said;
Update on my Flyer/mudguard/tyre issues...
I've now got a new set of wheels for my Flyer with Rigida Chrina rims. These are narrower than the Alex rims that came with the bike and since switching over I've had no rubbing problems at all (been on for about a month now and I'm running 28mm Gatorskins as before), so I imagine the width of the rim must affect the profile of the tyre and it rubbing on the guards (35mm SKS chromoplastics). Freewheel also packed in and that has been replaced with a White Industries one. Running like a dream at the mo :-)
Don't understand why it can't be a touring bike - you can tour on anything, just depends how much you want to carry...
