Improving fixed cadence
Discussion in 'Fixed Gear and Single Speed' started by fossala, 20 Jan 2019.
Tags:
  1. fossala
    fossala Veteran
    Cornwall
    I seem to be spinning out each day at around 160rpm on my commute. I want to increase to push my maximum speed downhill. Any tips on how to get faster, my main problem is smoothness once around 150-160rpm?
    Heltor Chasca likes this.
  2. mcshroom
    mcshroom Bionic Subsonic
    Egremont, Cumbria
    Fit a bigger gear and live with it on the uphills?
    I've not ridden fixed much since I broke my arm doing it a few years ago, but what seemed to help me spin a bit quicker was to concentrate on pulling back/up on the lower pedal rather than pushing on the higher pedal. I found my knees felt less locked that way. Also a slightly lower saddle can help.
    HLaB likes this.
  3. Soltydog
    Soltydog Guru
    near Hornsea
    I've not rode fixed, but single speed & it's all about getting the right gear. No real hills round here, but the wind is a killer. On initial set up I was spinning out at close to 30mph , with a tail wind, but then riding back into the wind was a real killer. Dropped a couple of teeth on the rear cog & all's well, but still wouldn't fancy riding in any kind of wind :okay:
  4. OP
    fossala
    fossala Veteran
    Cornwall
    I can't gear up, I'm at 72" and live in a very hilly area. My commute peaks at 12%, has a 10% average for 1 mile and has around 1200ft climbing over 10miles.
    I think I just need more practice, Rome wasn't built in a day...
  5. Dave Davenport
    Dave Davenport Guru
    Hampshire
    I find getting low on the drops helps a lot,. How fast I can spin depends a lot on the state of the road surface and how straight the road is, on a 76" gear 160rpm is about my max unless it's a nice smooth surface and straight when I can manage about 180rpm.
  6. smutchin
    smutchin Cat 6 Racer
    The Red Enclave
    Practice. Practice. More practice.
    You need to have the confidence to let go a bit and try to go with it. Keep pushing yourself and you'll find it gradually gets easier (though I don't believe anyone ever feels truly comfortable at 180rpm+ or can sustain it for more than a short burst). Also remember when you're getting to the outer limits of your comfort zone to keep your brakes covered, and be very mindful of not forgetting to keep pedalling.
    dave r, Ian H and mcshroom like this.
  7. Yellow Saddle
    Yellow Saddle Veteran
    Loch side.
    I can't help but wonder why not just get a bike with gears? But, with that knowledge freely available, consider it a rhetoric question.
    raleighnut and Slioch like this.
  8. midlife
    midlife Guru
    Way back when I rode a lot of fixed (we all did) , at high cadence (twiddling) there was a limit where I just started to bounce around. Despite several years of trying I never seemed to break the limit..... I guess it was just that my legs couldn't move that fast lol.
    alicat and Smokin Joe like this.
  9. OP
    fossala
    fossala Veteran
    Cornwall
    Something I've noticed is that if I'm applying a little bit of brakes my weight shifts forward causing more tension in my upper body. This make me less "loose" and makes the higher end of spinning harder.
    I've got a Specialized singlecross turning up today to commute on (my BJ w/ dura ace is to nice), may try bullhorns to help up the hills and have a larger area to brace my hands against when braking.
    smutchin likes this.
  10. OP
    fossala
    fossala Veteran
    Cornwall
    Cant' help but wonder why you don't just drive, after all it's easier...
  11. smutchin
    The Red Enclave
    If you've never descended a 15% gradient while clinging on to your bike in sheer terror, bouncing in your saddle with your feet spinning at something approaching 200rpm, you simply haven't lived...
  12. Yellow Saddle
    Loch side.
    I suppose I did ask for it.
    OK, above 160rpm, it is no longer a matter of muscle conditioning but neurological conditioning. Bouncing is introduced when the returning leg muscles are still firing and provides a bit of resistance to the advancing leg. You have to condition the nerve pulses. This is best done by training on a stationary bike so that you can focus on technique rather than a hill crisis coming up. Some people claim they get big improvements in this conditioning from training with a Powercrank. These gadgets prevent one leg from interfering with the other and helps to train the muscles to release quicker on the upstroke.
    I had a go on one of them once fitted to a road bike. It was a very strange sensation.
    Give that a go. See if you can borrow one somewhere.
    fossala likes this.
  13. Yellow Saddle
    Loch side.
    I used to get my kicks from chasing trucks and then sitting in the incredible slipstream just centimeters away from the tailgate. Somehow that feels safer than your 15% 200rpm gyrocopter scenario.
    I have lived.
    I like to think I've grown up but truth beholds, I just got too slow to catch them anymore.
    Sharky, KneesUp, Dogtrousers and 2 others like this.
  14. Alien8
    Alien8 Senior Moment
    I start bouncing about not much above 130rpm (on 48x15).
    How rubbish is that?
  15. Sharky
    Sharky Veteran
    Kent
    Don't have a cadence monitor, but I maxed out on the "ski-slope" start on the Tonbridge bypass once, at 44mph on a 95" fixed, which equates to just under 160 rpm. Was bouncing around and was really scary - only just resisted using the brakes. In spite of the fast start, my average at the finish was only about 22 mph.
    On the bike I used for commuting (when I was working), I rode fixed (68")for a long time, but the route was up and down Kent's North Downs and was pretty wearing, especially on the descents, so switched to a single freewheel, which was much more comfortable and faster on the descents.
    Dismiss Notice
