slowmotion
Quite dreadful
- lost somewhere
My bike has Campagnolo gear cables which run inside partly inside the frame. There is no barrel adjuster for the front derailler and I'm thinking of installing an in-line one between the shifter and the point at which the cable goes into the downtube. Is this likely to create more problems than it solves or is it a good idea? I'm thinking of using a Shimano SM-CA70 with the existing Campagnolo Ultra Low Friction cable which is 4.1mm diameter. Will that be OK?
Any comments would be greatly appreciated. Thank-you.
