nickyboy
Norven Mankey
- You want hills? We got hills
I can be a lazy so and so.
After I last wore my neoprene overshoes last winter I just chucked them in a cupboard and forgot about them. Of course the roads are salty in the winter and, guess what, when I've come to get them out of the cupboard both zips are completely immovable.
No amount of pulling and yanking had any effect. Around the metal bit of the zip was some white residue, presumably from the interaction between the salt and the metal.
So I started googling. And I finally found a scuba diving website. Obviously they have similar problems what with diving in the salty sea. They suggested the following....
1) Soak overnight in warm water to dissolve as much salt as possible. Then rinse
2) ....and here's the weird bit.....liberally douse the zip in vinegar
So I did (1)...absolutely no effect at all. The zips were just as stuck as they were before. Then I did (2)...and amazingly the zips, with a bit of pulling, started working fine. Just rinse, dry and then I'll probably put a bit of grease on them
So thanks Scuba Divers, you've avoided me having to buy a new pair of overshoes
