- Glasgow
I know it is a prong type of tool, but don't know the name to buy it.is that not coin or medium screwdriver size, or is ther more to the problem?
Can you post a clearer picture with something that gives an idea of the scale? Thank you.Hi lovely cafe dwellers
I need to buy a tool to open the plastic cover of the light fittings in the communal close, to change the light bulb.
Trouble is I don't know the name of the tool, nor indeed what it looks like.
Here is a picture of the lock, thanks in advance for your help
A proper electrician would knowA c**** device devised by daffodils to only be opened by daffodils - you're farked
Size is about a 50p piece.Can you post a clearer picture with something that gives an idea of the scale? Thank you.
As would a proper daffodilA proper electrician would know
They are light fittings commonly found in block of flats here.
Will get more pictures tomorrow in daylight.
I was told by the postman upstairs his electrician pal told him it's a forked type of tool, similar to a carving fork. size of the round is like a 50p piece.presumably you don't just stuck a scredriver in the slot and twist then?
What size is the round it?
Will try tomorrow, will try the screwdriver too.Not trying to be funny but have you tried a coin ? (50p or otherwise?)
Thanks for that!
