Gixxerman
- Market Rasen
This is off my Dahon Vybe C7A folder. The chain was at the 1/16 wear limit so I changed it. I did notice the old chain skipped a bit in top gear under heavy power. However the new chain does it a lot more. So I took a closer look at the cassette (actually a free wheel) and top gear looks to be a bit worn.
If it is knackered, I will be using the opportunity to raise the gearing a touch as I top out too easy in top gear. The standard gearing is 7 speed 14-16-18-20-22-24-28. I have found an 11-28 7 speed (see link).
Will this fit and work OK?
https://foldingbike.biz/Sunrace-Cassette-7-Speed-11-30-Teeth
Scratch that, I have just realised that that is a cassette not a freewheel. Damn.
