Jammed quick release mechanism on Bkool Pro
Changed bikes on the Bkool today. Got the Ridley set up to go and basically as the thread title suggests the quick release lever you pull closed when the bike is in position is stuck in the open position and will not budge. Mightily pissed off. Anyone else experienced same, or has a solution?
Winnershsaint
Tiny spray of TF2 and a bit of wiggling seemed to have solved problem. Will have to do this regularly as it seems it doesn't like the British autumn in the garage
