Lawn aerator
Any budding gardeners on here ? I need to aerate my lawn as it’s heavily waterlogged. Any advice on a cheap but good one to buy. Hand operated as no room or spare cash for an expensive powered one
Slick
I hire one every 2 years to get sand in to the soil. Not cheap but a lot less effort with much better results than spikey shoes. :okay:
T
Tripster
Can I ask which you hire and where from ? Im guessing make the holes and then put horticultural sand in ?
Retired (sort of)gardener here.
Forget those spikes on your feet. Useless. You will get tired long before your lawn is finished.
Forget those hand held spikes, garden forks etc. Yes, they do the job but its damded hard work and will take a long time.
You won't/shouldn't need to do this every year.
Best, by far, option is to go to your local tool hire shop. They will have a petrol driven machine. They will deliver. Choose the hollow spikes. Shouldn't cost more than £20 for a morning (unless you are in London where the sky is the limit!).
Machine will pull plugs of soil out of your lawn. Sweep these up and they make excellent loam to use on your garden.
Recommendation is to brush sharp sand into the holes that are made. At this time of year good luck trying to do that. But I seldom bother; I leave the holes for aeration and drainage. The sides knit together quickly and the grass regrows in no time.
You could ask someone like Green Thumb. They will do it for you, but obviously they will want paying.
I always just hire a machine for a morning. If you know anyone locally who wants their lawn doing then that splits the cost.
Manually aerating a lawn? No thank you.
PaulSB
Can I state the obvious please. Use a fork. Push in vertically to the depth of the fork and then pull the tines out vertically. Don't rock it back and forward though a little wiggle to help loosen is fine.
It's time consuming but cheap and will give a good result. You could also brush sand in to the holes to improve drainage.
Don't do this until your lawn has dried out.
Slick
T
Tripster
I gather the holes close quickly. The lawn is on clay soil and heavily waterlogged. Live on a hill and the garden is stepped down from house, split level house over 4 floors, so getting heavy aerator down steps not easy but doable. Forking is simpler but not working. Also have flocks of starlings feeding on crane fly larvae in soil :sad:
T
Tripster
Thanks for the advice, very much appreciated :okay:
