mickle
innit
- 53.933606, -1.076131
If it is a genuine leg length discrepancy and not a back issue (and it's not more than about 8mm) shim the cleat. Crank shortening can only be done where the new pedal hole doesn't ovelap the original hole, so only suitable where the discrepancy exceeds about 15mm. A shorter crank will describe an overall smaller diameter and this will have an (however slight) effect on the leverage ratio (ie. gearing). If you reduce the crank length by 50% - for example - you double the effort required to push it.
