LEJOG on a Brompton in 7 days
Tenkaykev
Poole
T4tomo
Just followed the link in my email from Brompton. Be interesting to find out what caused the gears to fail. Three punctures in three days is really bad luck.
give 3 out of 6 failed - sounds like a the rear sprocket change issue and hub gears were fine.
3 punctures could also be poor tyre choice
Kell
Kell
Definitely sounds like a chain pusher issue.
I had it happen once when the little hex bolt dropped out of mine. I think it left me with 2, 4 and 6 (rather than 1, 3 and 5). Happened right at the bottom of the mega hill on my commute.
I was very lucky in that the bolt came out of the frame but stayed attached to the chain pusher- so when I finally made it back home, I stuck some thread lock on it and it's been fine since.
609497
