Lengthening a chain on a 3-speed hub
Chris S
Birmingham
I've got a Batavus with a 3-speed hub, it currently has an 18-tooth sprocket on it.
I want to replace this with a 22-tooth sprocket but there isn't enough length in the chain (the bike has close-fitting mudguards so I can't just slide the wheel forwards)
Would I have to add another 4 links to the chain (one for each extra tooth) to get it to fit?
yep ^_^
Hope that works.
I tried something similar, but two extra links made the chain too long, and one extra made it too short.
Very little movement in the wheel due to tight mudguards, so I ended up with a chain tensioner.
Looks fine:
Chris S
Chris S
Birmingham
Thanks - my wheel is right up against the mudguard with the current chain length and a 22 tooth sprocket.
I reckon two links (one inner, one outer) should make it useable again.
If it doesn't I'll just put the chain back to how it was and get a 20 tooth sprocket off ebay.
Go on lash out on a new chain, I just got a track and heavy duty one for less than £8.
further
That is very clean isn't it.
