Lights! AA Batteries?
C
chillyuk
Buy a few triple A batteries, they are cheap enough and problem solved. Simples.
anyuser
Cateye rear light TL-LD1100 uses AA x2 and front light HL-EL520 uses AA x4. There may be others on the Catey site if you browse.
PpPete
Chandler's Ford
I did find one (Raleigh branded IIRC) but the switch was crap and the bracket failed, scattering bits of plastic across the road. It wasn't quite as big & heavy as the LD1100, but not far off.
Someone then pointed out to me that two Smart 1/2Watt (2 x AAA each) weigh less than a AA-powered light + 2 spare AA batteries..... which rather negates the argument for AA in my book.
I've had the Raleigh dual 1/2 watt rear which takes AA's, but my second one died last week - they don't like rain at all, despite being sealed with electrical tape !
DuncanBeaumont
Thanks for that. Ordered from Wiggle.
subaqua
What’s the point
Leytonstone
self almagamating tape is what you need. NOT electrical tape which is about as waterproof as blotting paper.
Wobblers
Euthermic
Minkowski Space
An AA battery has the same amount of energy as 3 AAA batteries. So you'll potentially get more light or more runtime (or both). There is also the factor that a larger light actually has more visual impact - it's more noticeable - than a small light. When it comes to lights, small is not necessarily beautiful.
albion
Planning ahead I tested my bright 5 year old Cateye LD600. (uses AAA)It lasts a good 8 hours solid and 16 hours 5 flashing.  No doubt with 1 flashing it is 80 hours.No doubt the newer model is brighter and/or more efficient.So for most people is probably fine for a whole weeks commute.
That was with old 800mah batteries
PpPete
Chandler's Ford
All true, but the only reliable AA powered light I know of (Cateye TL-LD1100) uses a lot of low powered LEDs (10 of them IIRC) No doubt the 2 x AA will last a very long time even so .... but in terms of (my perception of) visual impact, I think the Smart 1/2 Watts are way better, even though the lit area is a quarter the size. That is why I bought the Raleigh with its 2 x 1/2 Watt emitters running off 2 x AA, because like the OP I wanted to use AA throughout. I thought it sounded like the best of both worlds, but sadly the build quality was just not good enough.
