Lights. CREE XML XM-L T6 / U2 etc Thread
david k
Hi
North West
I thought about adapting the top of an old water bottle and putting the battery inside. Then it can sit in bottle cage.
There is also a better bracket on ebay if you wanted one.
but then how do you carry your water?
RWright
North Carolina
I find the strobe on the T6 very nice on this 2 mile yet unopened section of highway I ride. Put it on strobe, turn up your mp3 player all the way and play some Crystal Method...Magic Carpet Ride remix is my favorite strobe song so far. :thumbsup:
BSRU
A Human Being
Swindon
I have the Fluxient 3000 lumens thing from torchy and obviously it's way too bright on high, even medium, for road use. I run it on low pointed slightly down and it lasts 12 hours, works really well. Off road or empty dark road and the highest setting becomes very welcome.
I have the same light, quite spectacular on unlit country roads, lights up the road way into the distance.
wanda2010
London
My T6 lasted 2 weeks before the battery died last night. Worryingly (or maybe it was due to my zen-like mode on the way home) I hadn't noticed any colour change to the power light. I know it was showing green when I left work and for up to 1/3 of the way home, but can't recall anything after that. Fortunately I always ride with two front lights so the Hope 1 did it's job. I think I'll go back to weekly battery charging from now on.
Musa, I've not got a 'spares' box so I'll to visit my local hardware shop tomorrow to find a suitable screw.
potsy
Rambler
My Armchair
How many hours run time was that wanda?
Definitely needed a back up plan with these, wouldn't want to be relying on a cheap as chips light only :eek:
wanda2010
London
@ Fossyant - cheers for that. I thought I might have missed something.
@ Potsy - that was about 40mins a day M-F last week then again til last night, plus 1 hour last Saturday. About 4.5 hours in total. On the lowest setting - no flashing.
musa
Surrey
Unfortunately my light only remains on unless i disconnect the male female pins. Tried to fettle with thr hope btscket and slightly over screwed so what next?
Are you cycling through the modes as it's off, full, medium, low, off ? If you've over screwed it, does that mean you've stripped the thread ?
musa
Surrey
The on off button is now rendered useless. Only full mode no changes down so either i source a unit separately (uk stock) or buy another full set maybe keep this light and buy a y split cable and run two off the battery pack
The screw probably to far in into the unit touching something or disconnecting some connection
potsy
Rambler
My Armchair
I assume you've taken the screw back out now musa?
Could tell the one I used was slightly too long, packed it out with a couple of washers to stop it protruding too far into the light body itself, obviously there's a limit on this and you need to be very careful when fettling.
Hope @wanda2010 takes care with hers, less is more and all that :thumbsup:
