Jolly (Sailor) good ride. A new champion in the from-London ride category? I think so. Great route, great halfway stop, and a most excellent pub breakfast (though the service was a little chaotic). OK, Dr Beeching put paid to a direct train to points homeward, but it's not much bother to get six or seven miles to the nearest station, or to bail at Hatfield Peverel if you're knackered/have Real Life getting in the way/whatever else.
Back to Friday night. As ever, 9.38 Post Work Sprint Challenge not helped by work going down to the 9.30 wire. I nonetheless win the challenge, out the car park at 9.33, on the platform at 9.36. Just my luck, train is running late, by eight or nine minutes. Hardly a problem, still into Waterloo before eleven, where Martin and Tom were already at the Costa, then round to the NT.
Decided it was about time Chutney got an airing (having been resting since last year…!!), and to their credit no-one needed to have the laws of physics explained to them (i.e. 'Don't you have to pedal really fast with those little wheels', etc- as opposed to those larger, heavier, higher drag, slower-accelerating ones, of course
). I took it for a spin Thursday morning, and got reminded what a fun ride the little scamp is. And definitely not slow. I've done Brighton and back at a 13.7 mph rolling average, the ride from Eastleigh station to work on Friday was 15 mph average. No problems, most of the ride, bombing along very nicely. Though certainly better when you have the DualDrive hub gear working properly…more on that anon. In view of The Chain Incident, which Nick naturally referenced in the safety talk, and the Non-Standard Parts, I went for the belt and braces approach on spares…all four of my 20" inner tubes, pedal wrench (for the bolts on the hub gear), plus PDF manual on how to remove & reinstall the rear wheel (as with most hub gear systems, not exactly a simple or straightforward procedure)…of course, none of those were needed. Something else would be....
First stretch didn't quite go to plan. About half of the ride ended up going the wrong way! We should have gone up Farringdon Road as far as Rosebery Avenue. For some reason (as Martin stated, the consensus later being reached that Random Bloke with a Bike At A Junction was confused with a wayfinder) we ended up going right onto Charterhouse Street. Those of us who knew which way we should be going made the necessary arrangements and we got the group back on track, before I went back down Farringdon Road to check no-one had got left behind marking (been there, done that). Back on course, and onto that remarkable thing, a segregated British cycle route that doesn't suck. Warnings about possible ne'er do wells in Wood Green and its environs proved thankfully unprophetic. After 20km, we got a bonus rider. James and his very nice Mercian, with somewhat unusual gearing (inner ring barely smaller than outer) asked what we were doing, asked if he could tag along, though he wasn't intending to go as far as Maldon, he ended up riding from the pub to the pub
Apart from being joined by James, the 'burbs proved uneventful. And once out into the countryside, a very fine route indeed. Certainly not the most direct route, but we've been that way before. Romford? Brentwood? We could do better, and we did. On past Sawbridgeworth to Hatfield Heath and our halfway stop, the Village Tea Rooms. Host Jackie did a very fine job. I agree with Nick that cheese and cheese alone would have been fine for the sarnies. As for the cakes: nom nom nom. And I'm sure we all appreciated the commemorative bunting in our honour!
I will be back (just been checking out the menu...yup, good stuff).
What was good in the second half? Pretty much everything. What wasn't? My front shifter cable. The DualDrive hub is a 3 speed, that unlike most hub gears is designed to work in combination with a rear derailleur and cassette. Instead of, or in addition to, multiple chainrings, the hub gives you 37% extra upper/lower range, you can shift at a stop if you're in too high a gear, no cross chaining, and it's particularly handy with smaller rear wheels. SRAM did dedicated shifters, but it also works with regular Shimano STIs. Chutney effectively has, with a single 53t chainring, something like 53/39/30 on a 700c bike. Top gear is just as high, bottom as low or lower. Well, it did until all of a sudden the hub didn't seem to be shifting, at all. The cable coming out of the left hand shifter was very loose. And entirely non functional at the other end. I think it left me in the top gear. Climbing on 53x27, even in Essex, isn't that easy (good job the 6% was out of the way in the first half). Rather more grinding, and walking, than I'd have liked for the rest of the ride. Will be going to the LBS in the morning to get that sorted, or booked in if need be. Bob offered to try fitting a new cable on the train, but I declined (I know from past experience what a faff these hubs can be when they have Issues....).
On to Maldon, as lovely as I remembered from the previous visit. The Jolly Sailor's ordering system seemed a little chaotic (if you've got a table number for an order, why not take the order to that table...?) but everyone got the food soon enough, it was good and the view was lovely. In view of the hub problem, plans to ride to Shenfield for the train home were canned, and I joined Team Rob heading to Witham. Good call- more trains than Hatfield Peveral and nearly as close. A bit grindy, again, but no real problems. Train back to LST was a bit sardines, we were all crammed into doorways, but no real problem. The ride south to Waterloo was thankfully quick, and I made the next fast train south.
Great job Nick (we've all been there done that with the Garmin stuff!), and thanks everyone. Chapeau to
@Salty seadog for getting that first ton (and 'hey, that's a[nother] nice bike').
Same again next week? Don't mind if I do.
PS: An odd coincidence. We passed south of Pleshey, noted in recent years for its pub, the Leather Bottle, in turn noted for its recent tenancy holder, Keith Flint. Yes, that Keith Flint, of The Prodigy. He had a charity swear box ready for when he lit the fire
He gave up the tenancy suddenly last year (the pub has now reopened and is doing well under its new management, according to recent reviews). I saw the signs and that instantly came to mind. At Witham station, there's a news kiosk outside. Punter talking to the newsagent, about…Keith Flint giving up his pub!
