ChrisEyles
- Devon
I am having a bad day in the shed today
Started off trying to tweak straight a slightly bent derailleur cage (after checking the hanger was OK). Thought I'd take the derailleur off to pop the cage in a vice and do it "properly". This worked fine, as far as I can tell.
However, I have just popped the mech back on the frame, and it is now failing to take up any of the chain slack. It's a bit like when the B-limit screw is too loose, only 100x worse, so the jockey wheels are skating over the sprockets in all gears, with a big swag of chain hanging down. My guess is that the spring where the mech bolts onto the frame/hanger has unwound itself so the mech is no longer pivoting back to take up the chain slack. I've tried to turn the spring through 360 degrees to retension, but this seems too much (more than I can do with my fingers), and I can't hold it in place while I screw the mech back into the frame.
An hour or so of swearing in the garage has made no positive difference so far, so I thought I'd see if anyone smarter than me about these things has any tips before driving myself mad!
It's an old (ca 1997) Shimano Acera mech, if that makes any difference, and is bolted directly onto the frame (no removable hanger).
Thanks in advance for any help!
