Reynard
- Cambridgeshire, UK
Given up on the side panels for the driver's cab. Quite frankly, they're garbage.
My fault really, I was trying to be too quick / greedy / clever in making them, and it showed. Especially compared to the neatness of the other bodywork panels I've made. The issue is that this part of the bodywork has a lot of subtle curves and direction changes - not a problem when making a full-sized car when you've got a sheet of metal and all the right tools, but far more so when working small scale and with a very different material.
I could've carried on and bodged the originals, but I'd never have been happy with whatever result I'd then ended up with. Better to cut my losses now and start again from scratch. This time, being a heck of a lot more careful and thinking about each step.
Not all the ideas from the originals were ditched - the card frame survived, but instead of keeping it as a single piece, it got split into three sections, and fitment brackets built in at this stage. And to get the curves, I used small panels that butted up against each other rather than try to achieve it with a single piece of card / wire mesh / plastic bottle etc.
They're only at the single skin stage at the moment (120 gsm card) so plenty more work needed to get them finished, but the result is a much neater pair of panels with the right shape and curvature this time. Not just that, they simply just click into place and stay there, rather than needing copious amounts of blu-tac and still not really staying put.
I also need to make the rear panel at this stage, to make sure everything fits together.
