Reynard
- Cambridgeshire, UK
That's amazing @Reynard!
Thanks
Looks good, not easy to do in wood.
Is there any reason you picked that rather than plastic card and plastic sections?
You're going to get the best finish with an airbrush. You could try using a brush and humbrol enamels but won't come out great.
Rattle cans might be a better alternative.
How do you rattle can a tiny detailed model then ?
You could try Humbrol enamel paint . It used to stick to the little Airfix plastic figures. It takes a bit longer to dry as it dries by oxidation .
I will need to buy something of that ilk to paint the few plastic parts that I have.
Although according to Mr Google, nothing will stick to epoxy without flaking - even Humbrol - so I'll have to re-make / modify the parts where I've used it.
Your model will be kept indoors so it will not suffer from weathering or flexing . You could try a bit of wet and dry to roughen the surface up before painting .
I've already tried that with some of the plastic parts and / or test pieces, and no, artists acrylics will not stay put.
The results look good but the finish scratches really easily. IMHO it's not worth putting in all the time and effort to get the paint right, only for it to fall off as soon as it's touched. I don't need many colours (black, white, raw umber, burnt sienna) so I will be investing in specialist paints for those parts.
I was referring to enamel paint . Artists acrylic or even modellers acrylic paints will not adhere to some surfaces . I was angry when the acrylic paint peeled off the hull of a plastic model . It might be because I didn't use a primer but I have never used a primer for enamel paint .
Ah booger, that must've been really frustrating...
You'd think though, that the people making modelling stuff would make it in such a way that the paint does a stayputnik.
