JackE said:that the maximum weight advisable on an Audax bike was around 10kg. I used to have a Dawes Audax and even with 700x28 Marathons, I wouldn't have wanted to go above this weight.
My clip-on seat post rack is rated at 8Kg!
ch3 said:On a similar topic, is there any chance at all that a carbon fork may fail because of heavy load, let's say while going downhill and hitting a hole or something?
I think you're getting it confused with kevlar, (see table below).In compression, carbon is pretty weak. Essentially, it is the epoxy that takes most of the compression force.
Simply not true.Essentially, it is the epoxy that takes most of the compression force.
There is no common point of failure. Carbon fibre forks are extremely reliable. So much so that they are commonly used on bikes! If manufacturers had any worries about their reliability they would not choose to use carbon fibre for this, the most highly loaded part of a bike. All forks of any material can and do fail. Where is the evidence that carbon forks are less reliable or suffer 'common failures' ?If you hit a bump at excessive speed then the rear face of the fork blades get heavily compressed and this is the common point of failure.
Tim Bennet. said:There is no common point of failure. Carbon fibre forks are extremely reliable.
How common? Do you have a percentage figure of all carbon forks made? How does this compare to steel fork failures?But by far the most common point of failure is the blade/steerer interface area.
Tim Bennet. said:How common? Do you have a percentage figure of all carbon forks made? How does this compare to steel fork failures?
Tim Bennet. said:I think you're getting it confused with kevlar, (see table below).
Simply not true.
Tim Bennet. said:There is no common point of failure. Carbon fibre forks are extremely reliable. So much so that they are commonly used on bikes! If manufacturers had any worries about their reliability they would not choose to use carbon fibre for this, the most highly loaded part of a bike. All forks of any material can and do fail. Where is the evidence that carbon forks are less reliable or suffer 'common failures' ?
Tim Bennet. said:ICarbon fibre forks are not used for touring bikes because the weight saving is not an issue on a loaded touring bike and the inherent conservatism of touring cyclists. But if there was a demand, engineering a touring fork in carbon would be no problem.
Chapter 1 in any Composites handbook will tell you all you need to know.How can a weave based on string fibres be strong in compression?
Really? So the crash cell in a Formula One car isn't made of carbon fibre because it can stand the repeated impacts of flying through the air and tumbling along the track into the armco barrier at nearly 200mph.Carbon is not a resilient material when it comes to impact strength.
