Harrisman
- montrose scotland
Any on here
Any on here
Dayvo. i have a set of miche 707 race wheels. fitted with a campagnolo freehub. can i change it to a shimano freehub.
Who is?Bike mechanic
He wasn't asking you, he was asking Dayvo.I can answer that question - and I'm not even a qualified bike mechanic. The freehub body should be able to be swapped out for a shimano item - but you will, at the very least, need a Miche shimano freehub compatible with the Miche hub on the wheel.
Ok thanks.I can answer that question - and I'm not even a qualified bike mechanic. The freehub body should be able to be swapped out for a shimano item - but you will, at the very least, need a Miche shimano freehub compatible with the Miche hub on the wheel.
