Reynard
- Cambridgeshire, UK
The problem with that is if the appliances are faulty then it’ll trip the power inside the rest of the house.
If you suspect it’s the socket circuit then Unplug everything in the garage and try resetting the trip. If it doesn’t hold in then it could be a wiring fault. If it holds in then plug in your appliances one at a time and see if it trips and with what appliance. If it does then try again in case it’s just nuisance tripping and holds in the next time. If it persists in tripping out then that appliance could be faulty, or maybe damp. Hard to say for sure when I can’t see it.
That's much what I planned on doing.
The house is fine, it's just the garage / utility room.
Everything seemed fine yesterday teatime when I went to the garage to get some logs. Lights turned on fine. So between then and early afternoon, something's gone awry. The only things that were physically turned on and working at that time were the fridge and freezer.
When I tried a reset of the box, I heard a klunk, and then straight after, a second clunk.
I suspect the culprit is either the fridge, the freezer or the multi socket they're connected to. It's a double power point, but the washing machine is plugged into the other side.
