Set your general position in the order:
Crank length
Saddle height
Saddle layback
Bar length
Bar height.
Then make repeat adjustments as one factor affects another.
Once your general position is good for you, fine tune:
Bar angle/shape
Saddle angle
Brake position.
The best guide for non racers is by Peter White.
https://www.peterwhitecycles.com/fitting.php
Many guides make assumptions about how you want to ride or how athletic and flexible you are.
Also check that you are riding symetrically, with flexed elbows, straight wrist, relaxed shoulders static hips, a straight back and not cranking your neck back or sideways.
Crank length
Saddle height
Saddle layback
Bar length
Bar height.
Bar angle/shape
Saddle angle
Brake position.
