biggs682
Touch it up and ride it
- Northamptonshire
In randynewmanscat close up is the tapered bit and the thin grid bit underneath all in one?
I think so
How far does it turn left or right ?
it should just keep turning up the threads then pop off
These are usually 3 separate components. So the knurled and bevelled top piece spins freely if you screw it "righty tighty" down? My rubbish amended MS paint image sort of shows what should be 3 different parts. View attachment 447415
ok i have turned it anticlockwise and it has got a little easier to turn but that is all.
That's clever how you done that . but yes the blue bit just spins both ways its not biting on anything if that makes sense.
has a gap appeared between the blue and red parts on @randynewmanscat picture ?
The more i look at that it looks like one i had on a 90's Giant Peleton a while back that had a push over trim part that popped up to reveal the top nut underneath
yes 30mm or big pr of pliers does same jobI have to get a spanner to fit I have just measured it and it would be 29/30mm would that be right?
Well you were right..lol
@Boon 51 that was the hardest work i have had doing a headset strip and clean , and the bike was 100 + miles away , but you got there so well done , all looks good just add some good quality grease and then rebuild it .
Hope you are enjoying the rebuild , whats the next job ?
