Name and shame bad roads to cycle on
paul04
A day off work today, so thought I would have a ride around the outskirts of manchester, everything was going fine until I got to stockport road.(from manchester going to stockport)
Word can't describe how bad this road was, full of potholes, and big mounds of tarmac pushed up towards the kerb due to the weight of buses and hgv's.
It was almost impossible to ride in a straight line. I have highlighted it in red on this map, this is a road to avoid (unless you can ride in the middle of the road)
Rob3rt
Man or Moose!
Manchester
There are so many rubbish roads that it is not possible to keep track of them, thus this thread is a pointless endeavour.
Turret Grove in Clapham and Coldharbour Lane in Camberwell are both on my commute and there's more holes than there is road (and it means I can't nose through the windows of the posh houses).
screenman
Lincolnshire, take your pick the man in the lorry with a shovel full of tarmac is going to have his work cut out.
Old new from the Lincolnshire Echo
"The Echo then revealed how 80 per cent of Lincolnshire roads were in urgent need of repair"
Sod that going into work each day knowing only another 10,000+ miles to go.
Deleted member 20519
www.fillthathole.org.uk
Has worked for me locally :thumbsup:
If just half the councils were proactive then the roads would be a little safer to ride on.
Worked for me too, it took six months but worked nonetheless!
RedRider
Pulling through
And not too far from those is Evandale Rd where the potholes have potholes that have potholes. For me it falls into the category of 'so bad it's good'. On a mountain bike it must be a buzz. At one end there's a sink hole that opens every two or three months around a grid and if you listen carefully... three seconds after you drop a penny... you hear it... plink into subterranean Effra.
I know this thread is a bottomless pit of surface scratching but not if you're into potholes. Check out more stories about potholes at pothole.co.uk
Psycolist
NINJA BYKALIST
North Essex
Its not just the un repaired roads, in some cases, its the repairs themselves that make the roads dangerous. A couple of years ago, when the local council decided to contract out the minor repair work, we ended up with a flat back transit driving around, literally throwing some tarmac in a pot hole and stamping it down with a Doc Martin boot. It caused more work and expense to re-do these dodgy repairs in the long run and caused a period of very unsafe surfaces to ride on. There were a couple of routes that I stopped using for this very reason.
