Coming back from work heading along a very dark B road, felt the back wheel bumping along the ground. Oh bugger, a puncture. Had to walk about a hundred yards further along the road to find a safe place to deal with it. Got the wheel off, got the tyre off then - oops - I seem to have left the spare tube at home. My only option is to find the hole and apply a self-adhesive patch. Fortunately I did have the headtorch with me so I could at least see what I was doing, unfortunately the hole was big enough that when I tried to inflate the tube it went down before I could properly feel for escaping air. Spent several minutes frantically trying to pump as much air into the tube as possible desperately trying to find the leak. Eventually found it and managed to put a patch on, then had to be really careful to get the tube back in and the tyre on without introducing any grit and dirt that was all over the road. Can only get the tyre up to about 40 psi with my small pump but it was at least rideable and my fear of it going down a mile further along the road did not come to pass and I made it home without further problems.
If I hadn't managed to repair the tube I would have had a two hour walk home.
In future, I'll make sure I check I have the correct spare tube for the bike I am using.
