Non-cycling use of your multi-tool
nickyboy
Norven Mankey
Mrs N asked me to adjust a toilet seat. It needed a 4mm Allen key....that I didn't possess. A trip to Wickes was on the cards until I had a look at my multi-tool.
And there it was. So with a bit of fiddling about, I managed to sort out the toilet seat using the mutli-tool.
Someone must have found an alternative use for a chainbreaker by now?
ChrisEyles
Devon
I use the little knife on mine at work quite a bit to cut bits of baler twine etc, or if we've forgotten any screwdrivers/allen keys.... not fixed any toilets yet though, good work!
Vapin' Joe
Formerly known as Smokin Joe
It would be useful if you had to extract a tooth.
Loch side.
I regularly open bottles with mine, but strangely enough I've never used it for bicycle repairs and certainly never for a toilet job.
Diggs
I tend to use my cycling tool kit at home for some DIY chores as it's the one set of tools that I know the exact location (as opposed to the others that Mrs D has hidden at the back of a cupboard)
London
Not a multitool, but my threaded headset spanner saved me from a trip to the diy shop when i needed to tighten an odd thin plastic nut on my toilet. I advocate even more integration between toilets and bikes.
U
User33236
I've used the Torx T25 on mine at work whilst disassembling a defibrillator after the Torx drivers went astray one day.
At home they get used quite often as they are generally more ready to hand that the toolbox.
I have three of these:
We needed a tool to tighten an allen bolt on one of the doors so used my Mini tool:
It is now a part of the Radiopharmacy kit
