Noob advice - inner tube size
Discussion in 'Beginners' started by Earthwormjim, 10 Jul 2012.
  1. Earthwormjim
    Earthwormjim Regular
    I need a new inner tube for my hybrid. The one currently in it is 700 x 28/32C. Will
    700 x 28/38 be ok for a replacement?
  2. ianrauk
    ianrauk Tattooed Beat Messiah
    Atop a Ti
    yes it will be fine
  3. biggs682
    biggs682 Smile a mile bike provider
    Northamptonshire
    yes fine , just dont pinch them
  4. festival
    festival Über Member
    Probably.
    Without seeing it and the tyre its going in its hard to be 100% sure.
    This is due to different makers measuring and marking their tubes inconsistent with each other, e.g. I have one marked 700x 19/23 that is wider than another that's marked 700x 19/25.
    Having said that, If the new tube is a little wider it will be fine, but be sure to be extra careful when you ease it in
  5. OP
    Earthwormjim
    Thanks for the info guys. For the future, is there any other sizes I could get away with?
  6. Pauluk
    Pauluk Senior Member
    Leicester
    I'm only a novice jim but may be you should consider your tyre size first, then choose a tube that has a range to suit your tyre. At the moment I'm using 35mm tyres (35C) on my hybrid so I tend to buy 28 to 38. This means I can use them on my trainer bike that has a 28c rear tyre as well as my 35c tyres. Halfords are doing 3 for 2 today (£10 for 3) so they work out nice and cheap.
  7. ufkacbln
    ufkacbln Guest
    Do legally bought ones function better then?
    Psyklon likes this.
  8. biggs682
    Northamptonshire
    no but better quality ones do
    Dismiss Notice
