srw
It's a bit more complicated than that...
For reasons too dull to bore you with I've just bought a Presonus Audiobox external sound card (https://www.presonus.com/products/AudioBox-USB-96) and need to pipe the output through a 1980s vintage domestic amplifier to a pair of speakers.
The last similar box I had was equipped with phono outputs, which I'm used to. This one has two outputs labelled "Main Out", which are 1/4" jack sockets. The technical specs are below. Can I simply get a twin 1/4" jack to phono adapter (https://www.maplin.co.uk/p/prosound-twin-mono-14-inch-to-twin-phono-female-cable-10m-a87ry or https://www.maplin.co.uk/p/maplin-635mm-plastic-mono-plug-to-phono-socket-adapter-rw01b and expect it to work? Following the trail of explanations online leads me into a maze of words which look like English but don't actually make sense. I'm a musician, not an audio technician.
