one battery or two
numbnuts
Two big batterys
A single big battery will discharge slower and you may not draw it down as much.
So in theory a single battery will last longer.
But if you can get more amp-hours for a cheaper cost then two batteries are probably the way to go.
Also it depends on where you're going to mount them.
You want to keep the trikes CoG as low as possible, therefore its more stable on high speed corners.
So if you need to mount a single big battery high up vs two smaller ones lower down, then how brave are you ........ ^_^
CXRAndy
Lincs
How far are you expecting to travel in one day, terrain you're likely to frequent?
How strong are you? If you're just wanting assistance for hills one battery would probably do
wotsthat
wotsthat
Regular
southwark
well unsure initially up to the highlands and round Ireland - but have just seen "The Sun Trip" an annual solar powered event from Lyon to Canton
