DCBassman
- The lumpy far South West
My big Windows 10 box died yesterday. Looks like motherboard...
Rats.
Rats.
Sunspots, it must be sunspots...And my iMac's former occasional blackscreen issue which had gone away after my changing the HDD to SSD and giving it a good clean is back, too.
Rats.
The old girl's a bit long in the tooth, and they (Intel chips) do run very hot in this application, so I suspect it's heat-related.Sunspots, it must be sunspots...
Took the precaution of ordering a new SSD for it anyhow, as this one, an OCZ Vertex 4, is getting a bit long in the tooth.
I use Macs Fan Control on the Mac Pro, works well.The old girl's a bit long in the tooth, and they (Intel chips) do run very hot in this application, so I suspect it's heat-related.
If it keeps on doing it I'll load some fan control software and crank the fans up to max and see if it makes a difference (albeit it still has a fan control sensor, fitted by the firm who replaced the HDD the first time, so it should be responding to increasing heat itself)
Fine if you're happy to have all your stuff in the cloud, otherwise a bit under-specced!Whilst I'm rambling, this is used as a second computer for light duties only. Would a little Chromebook (something like this https://www.hp.com/gb-en/shop/Product.aspx?id=5SX33EA&opt=ABU&sel=NTB) work for browsing, video, and WP-type stuff?
I'm always a bit concerned when I see the specs because it's closer to a phone than a computer, but then I read that because Chrome it'll be fine - what say you?
ThanksI use Macs Fan Control on the Mac Pro, works well.
tis true - don't know if you know but I recently bought another chromebook.A friend is very happy with her Chromebook and @Blue Hills is with his, for those kind of uses.
My nephew wasn't pleased with his but he probably wanted to play demanding games on it, which was never going to work!
I admit, even as a Linux user, i use Chrome. I did use Firefox but i had issues with it. But i do use Google Drive, syncing and a few tools. I can understand the appeal of a Chromebook, as it does suit most tasks, most people do with their PC's...tis true - don't know if you know but I recently bought another chromebook.
£170.
It will get security updates until June 2028 and I am hopeful that it will do the full run.
It does everything I need - yep - no games.
You can do a fair amount of stuff offline.
They do have a fair amount of onboard storage and you can always shove a pendrive in.
In truth I like the fact that so much is on the cloud with the clever syncing and back-up - I was never very good at doing that and have lost lots of stuff in the past with other platforms.
Aren't chromebooks based on Linux?I admit, even as a Linux user, i use Chrome. I did use Firefox but i had issues with it. But i do use Google Drive, syncing and a few tools. I can understand the appeal of a Chromebook, as it does suit most tasks, most people do with their PC's...
I thnk you can run native linux if you are techie enough.
I switched to chromebooks after a windows laptop's life was cut short for no good reason - it was to do with an operating system update.
I once for the hell of it in a spoons wiped a chromebook and then resynced all the stuff to it/reinstalled all the updates.
I'd like to see someone do that with anything running on windows.
