Bodhbh
Hi all, as above. There's a little bit of play in the forks on my MTB. Not really noticable while riding, but you can confirm it's there easy enough by locking the wheel with the brakes and rocking the bike back and forth (if you lock the front and back brake alternately and apply forward pressure, you can 'walk' it forward slowly). It started to irritate me as the bike took time to get setup how I liked and everything else is finally in order.
I've changed the headset, it's still there, exactly as before. I've got a facing tool for the forks and faced them, used a headset clamp to fit that, so all by the book. Any ideas to the cause? Should I just ignore it?
I guess my main concern is it might be a crack in teh frame which is not visable or something . It's an aluminium Rockhopper frame, Kona P2 forks and Cane Creek S3 headset for what it's worth
