Plumbers world thread
Milzy
Can you use these onto Plastic speed fit pipe?
I have this eBay tap with the hole centres out so I can’t get my two speed fit hoses in together but it will fit the supplied flexi hoses.
608519
Milkfloat
An Peanut
Midlands
Not directly no.
The problem with using speed fit/flexi pipes and such isolators is that there is a little washer that gets crushed when you connect up to as it relies on compression to reduce the diameter at the fitting, it’s great for fit and forget but rubbish if your ever planning on removing again in the future as the washer is a one time use only and needs replacing when you do any work. You are better off using the proper speed fit isolators and or swapping to copper pipework.
Milzy
Milzy
I can get thousands of those olives from work.
Have you a link to a proper speed fit isolator please Sir?
slowmotion
Quite dreadful
lost somewhere
Speedfit used to supply rigid plastic internal sleeves to reinforce the plastic pipe against crushing when it transitioned to brass compression fittings. I have no idea if they still do. I'm not a big fan of plastic plumbing. It can get you out of a tight corner but it looks sloppy. It probably fits in well with the rest of the workmanship on a modern domestic building site.
Edit: I was referring to semi-rigid plastic Speedfit pipe, not flexible hose.
Milzy
Milzy
https://www.screwfix.com/p/jg-speed...V4ejtCh3RJwGZEAQYASABEgKcHPD_BwE&gclsrc=aw.ds
15mm diameter but you can also get 12 and 10mm. They are pricey but much higher quality and the valve is unlikely to stick.
If you prefer plastic then these are the suitable ones https://www.screwfix.com/p/jg-speedfit-15svp-isolating-valve-15mm/12372
I’m aware of these but you’re missing the point. I can’t have them because my flexi’s are nut fitting because the China tap doesn’t have room to accommodate my posh expensive speed fit flexis.
608553
newts
Isca Dumnoniorum
You can't attach the 1/2" nut on the flexi pipe direct to the end on the isolator (it's 1/2" but the end is tapered for an olive).
You'll need 1/2" male thread on the end on an isolation valve like this;-
https://www.bes.co.uk/flat-faced-st...7J1b72OaTOP-JBa7bnn_bIBYdgAnmc5BoCwX4QAvD_BwE
or a 15mm x 1/2" MI like this after the compression isolators with a short bit of pipe in between.
https://www.toolstation.com/made4tr...g8Yfiu4Hw4k5ji1zYnRoCgkIQAvD_BwE&gclsrc=aw.ds
Due to the limited space an isolation valve with 1/2" Male end is preferable.
Milzy
Milzy
There are inserts in the speed fit part. As far as I can tell the CP 15 I posted above will lose one end & fit the flexi pictured & the the other end will compress the olive onto the plastic with no dramas. And only 95 pence or grab two from work.
