MacB
- Farnborough, Hampshire
Some of you are aware that I've been trying to resolve my bar, brake and shifter issues without having to make expensive changes. Just been messing about in the garage and have discovered a workable solution.
Flat bars with ergo style grips
Titec Bar Ends
V-Brake levers, the left/rear fitted on flat bar as usual, the right/front fitted on bar end.
Shifters - the hub gear twist shifters can stay as usual on flat bars. The 3 speed is my shopping bike and I rarely change gear. The 9 speed is my commuter and I know all necessary gear changes well in advance. For the unexpected I can change when stationary anyway. Then we have the Giant with the 9 speed triple trigger shifters. Leave on flat bar on the left for the chainring shifting, again not used very often. Fit the rear shifter next to brake on bar end.
Add some gel padding and black bar tape to the bar ends and I'm sorted.
Additional benefit is that I can vary width of bars by bringing the bar ends in a bit. Can also whack some tri bars in the middle.
Oh, this is going to be so ugly, I'm going to love it, and the final added bonus is that the piccies may make 4F internally combust Sadly it will mean a farewell to the butterfly bars
Titec Bar Ends
