gbrown
Geoff on Bkool
- South Somerset
Continued from FAQ thread ...
https://www.cyclechat.net/threads/bkool-faq.191965/post-4053014
A 5% over read on bkool compared to your Vectors is not bad at all.
One thing with the Vectors is that they are measuring power at the pedal, whereas the Bkool is estimating power at the rear wheel, and a powertap is measuring it at the rear hub. There would always be some loss of power through the drive train, I understand this can be in the order of around 3%! So you might expect the Vectors to be around 3% higher than a reading from the rear wheel...
I would guess that most people are interested in the power they are applying to the pedal/crank, the fact that it is slightly higher than at the rear wheel is a psychological bonus!
Here I tried to speculate on why the trainers have limits on maximum gradient simulated and why this varies from person to person and trainer to trainer, not just due to the weight of the rider, but also the speed at which they climb and which gear they use.
https://www.cyclechat.net/threads/team-bkool-cyclechat.144689/post-3525607
Geoff
Has anyone compared the power that the bkool displays against an actual power meter?
Possibly, I am just reporting what I have found on my classic with v2.04 firmware (iirc). For me, my current ftp on bkool of 199w, came off of a ride average of 210w. The vectors reported 201w for a 20 minute average on the same session (a PB), one of the T100 stages. At lower to flat gradients I am getting an over read of up to 30w compared to the vectors.
I find, with my set up, that acceleration up to any speed and the power readings are almost identical. Once I am no longer accelerating and I am just holding a steady speed the power differences start to come in. How much depends on slope, cadence, speed and weight. The thing is it is a pretty consistant, for me, with my setup.
Geoff
