PBancroft
- Winchester
OK, so I got my new bike last week. I love it - but the tubes are Presta valves, and I've never used them before. I figured I should acquaint myself with them... and I seem to be incurring problems.
First off, I'm using a hand pump. I know I should get a foot pump with a gauge, but after the expense of the new bike I simply couldn't afford it. However... Every tube I've tried, I could pump it up to a certain pressure, but no more. Not as firm as the other tire, but firm enough. Fine - I remove the pump only to find the screw and nut on the end of the core is missing - sheared off. I'm fairly confident I wasn't wiggling the pump around THAT much.
This has happened on three tubes, I've just used my last one. I'm kicking myself, I really am. I now can't tighten the nut to restrict airflow. I would suspect that the airpressure would hold the valve shut, but even if so, I wouldn't want to commute on it too far, and I would want to know what I'm doing wrong anyway!
