Project Bike #1 - Apollo Equipe
bigfella
Essex
They are certainly hard to find.
What did you do about the holes where the badge was riveted on on the head tube?
I cannot seems to loosen one side of the bottom bracket (chain ring side), is it a left hand thread?
zzpza
zzpza
sorry, missed these posts. there were no holes as the head badge was a sticker(!). and yes, the thread is different on each side of the BB.
bigfella said:
Another question, did you manage to fit the sealed BB without any filing?
yeah, there were no problems converting from unsealed to sealed. the only problem i had was due to overspray on the thread.
bigfella
Essex
I had to take mine to the LBS to get the other BB cup out - charged me £5 which did seem a bit steep. He did run a tap through it though to clean the threads up. Took him about 10mins as it was pretty tight!
I had to get the holes on mine welded up in the end.
The LBS did say that I might need to grind/file away the protruding tubes inside the BB housing. Do you think this sounds likely?
