Ok hopefully you can shed some light on my issue. For the last few months I had completely lost my first three highest gears and my lowest gear on my racing bike, so as you imagine getting up the hills is a lot harder.
I have also lost the ability to use two rings on the front Derailluer as well
So the only gears I can use at the moment are 4567
My previous attempts at sorting out gears has always ended in failure so after some youtube tutorials I jumped in and had another go at it.
I decided to work on the back derailleur first. To prepare I made sure the I was on the lowest gear and I undid the nut the holds the cable. I pulled the cable tighter and tightened the nut.
No matter how tight I pull that cable I am stilling missing my three highest gears. I must have done this about four or five time snow. Do you have any tips you can suggest before I go running to the cycle shop. I hate being beaton by things like this.
Job is also harder since I don't have a proper bicycle stand to hang my bike either. Save money on the gears I can probably get a stand.
