rh100
Hi
I have a problem with my MTB. The bike has only a few hundred miles so far, BUT is now over six years old and was sat not doing anything all that time.
Now it's getting some use it seems to be showing a few problems.
Firstly, I have adjusted the high and low stops on the rear derailer and adjusted the tension, so when it is on a stand with the pedals spinning, pulling the gear cable or turning the gripshift the chain moves nicely up and down the gears, doesn't seem to hesitate.
However, when riding the bike uphill, and changing down gear at low speed say from 3 to 2, the pedals seem to start to spin too easy, even loose, before it bites and clunks in to gear and allows me to continue pedaling. This obviously causes a major slowdown in momentum.
I have this problem with two MTB's actually, both same age and both with Shimano SIS derailers.
Might be worth pointing out that I also had the chain derail from the front cogs, when changing down from middle to left, it came clean off, it might have been down to a bad gear change though as I've not had it happen before or since, and to be fair I havn't checked the H and L stops on the front yet, just the back one.
I'm not sure if it's a problems with the derailers or the chain - or is it likely the cable itself becoming a bit stiff? If so, do you have to buy a cable specific to the bike or just buy a length of cable, length of cable sheath and cut to measure? (any idea of cost?)
The second problem is that on one of the bikes, the pedals seem to groan when riding along, I'm 'fairly' certain it's the pedals because of the timing of it, seems to be worse on the left side going down rather than the right though. Also the pedals and crankarm (is that right? the pedal arms?) can be waggled back and forth slightly - it's as if the arm is loose within the frame, not by much but noticeable, and I'm concerned it could let me down far from home - any suggestions.
Whilst I'm fairly new to bikes, I'm not completely useless with a spanner and could do without the cost of a visit to the LBS unless for necessary parts.
TIA
Rich
TIA
Rich
