Big John
Here's one that should have you all scratching your heads. The following relates to a good quality road bike belonging to my clubmate.
When on the small chain ring and the largest sprocket at the back the cage of the rear mech catches the spokes of the back wheel. We've adjusted the LOW screw on the rear mech and this had some success but didn't completely cure the problem. We've checked the cage to make sure the cage isn't bent, which it isn't or doesn't appear to be.
We've re-indexed it and it changes gear sweetly across all sprockets. It's an 8 speed cassette, has an eight speed rear mech, chain shows no sign of wear and the gear cable is new. The chain length has been checked and appears to stack up with recommendations in the Bike Book.
To add to the mystery this problem has only arisen since we put a new gear cable on the bike. For the life of me I can't think why a new cable should have this effect.
The back wheel runs true and to the naked eye appears dished correctly. The wheel rim sits pretty damn central in the frame.
Any ideas/suggestions? We're toying with the idea of replacing the 8 speed freehub with a 9 speed and fitting a spacer to give a decent gap between cage and spokes when in the biggest sprocket but this may present us with further problems.
Help!
Help!
