yes, a lot of the manufacturers now to disc and non-disc racks, basically look the same but the frame fitting at the bottom is extended on the disc versions.
These are normally only needed if your disc caliper is mounted on the seatstay a lot of bikes are now being made with the caliper mounted on the chainstay and this allows the use of a standard rack.
