Thanks - I'll have a try.I clamp my defy on the seatpost
Thanks but I need it raised off the floor - the derailleurs need adjusting, Never been right since I got some grass caught in the rear set.It'd be OK in a U stand that clamps a wheel axle (but that leaves it stood on the floor) or a bike winch if you have suitable ceiling beams to bolt to.
Yeah, you can adjust the derailleurs with the bike on the floor and back wheel lifted in a stand, but it's a kneel down job. A winch is easier.Thanks but I need it raised off the floor - the derailleurs need adjusting, Never been right since I got some grass caught in the rear set.
Been trying that for a couple of weeks but as I have not yet managed to sort out the issue thought a higher arrangement might achieve a result. As it was, and it might be due to the clamp being worn slightly, but even as tight as could get the clamp on the seat post the bike still slipped down (also might be because it was swaying about slightly in the wind). Anyway decided I had spent enough time getting no where booked the bike in the LBS. However would still be interested if anyone knows of a stand that will clamp onto a rectangular top bar.Yeah, you can adjust the derailleurs with the bike on the floor and back wheel lifted in a stand, but it's a kneel down job. A winch is easier.
