paulmad
thinking of buying one of these from edinburgh bike coop. would like your opinions whether the cross sport is worth £120 more. revolution cross
- Lightweight 7005 aluminium frame and rigid steel fork.
- Eyelets front and rear make it easy to fit mudguards and rack if required.
- Maxxis Raze 700x35 - a cyclo-cross racing tyre with a fast-rolling centre ridge and widely spaced side lugs to shed mud. Its slightly softer compound remains pliable in cold conditions. Its stout casing helps maintain integrity at low pressures.
- Shimano STI 2303 Dual Control levers deliver perfect gear shifts via a nudge of the brake lever.
- SunTour chainset with 28/38/48t rings and Shimano 8-speed cassette with the 11-32 cogs deliver a wide range of gears.
- Higher geared than an MTB 22/32/42 chainset for a faster turn of speed on the road.
- Tektro cantilever brakes work well and offer tons of clearance for fitting mudguards.
- Gel-padded cork tape make the bar tops even more comfortable for resting your hands on as you cruise along.
- Weight: 12kg / 26.5lb (based upon weighing one example of this bike. We weigh the whole bike as you would receive it with pedals reflectors and bell - items many bike companies remove before weighing their bicycles. Weights can fluctuate between different sizes and builds so please regard our published weights as a useful guide.
- With its double-chainring compact 36/46 FSA Verso chainset, its improved Shimano Sora 2x9-speed gear shifting and its tighter 11-25 cassette (compared with the standard model's 11-32 cassette) this is a lighter weight, more sporty version of our Revolution Cross.
- Approx Weight: 11.3kg / 25lb. 1.5lb lighter than the cross. dont think will make any difference to me. but dont understand difference in gears. thanks in advance
