U
User65906
Hi everyone, am new to the site, and new to cycling.
I bought a Ridgeback day 00 hybrid, it has 700c X 25 Maxxis tires
on Shimano 500 wheels, these are original according to the booklet
that came with it.
It has an alloy frame, 24 speed, with straight bars.
It has done ten miles since new and I got it cheap.
I need some information on finding and replacing the back derailluer cable cover.
The bike sat so long the cover cracked a few inches above the stopper on the side
of the top tube, does anyone know if a special cable was used, the outside cable
dimension looks thinner than normal, or can I just go to a cycle shop and ask for
some cable sleeve, the bike changes gear no trouble, but the cables housing is
the issue, being so stiff it cracked, looks like a hard plastic outer with the cable
sliding inside it, I read that most cable covers are either specifically for derailleur or brake,
and in either case there is an inner guide of steel, either coiled for brakes, or stranded
for derailleur 's so to not lengthen or shorten when the cable housing is moved.
Any advise on how to go about changing this cracked outer sheath would be much
appreciated, even what brand of internal wire cable or outer cover is best, will last
a good while, for like everything else am sure some offerings are to be avoided.
Thanks and regards to all.
that came with it.
