Riding with fingers on the brake levers?
glasgowcyclist
Charming but somewhat feckless
Scotland
Always. Two fingers covering each brake unless I'm slowly climbing a big hill.
GC
Leodis
Moortown, Leeds
Frequent glancing over the shoulder every 8-10 seconds gives you a good awareness of the road users behind.
wtf...
In general when overtaking traffic you should always do it on the right. You never know when a car is going to turn left into your path without looking.
You never know when a car is going to allow another to pull out into your path.
Load of bollocks.
Wester
I always keep both paws on the brake levers at all times because I am cycling in London all the time
shouldbeinbed
Rollin' along
Manchester way
not constantly no but my levers on flat bars are angled so my fingers naturally fall onto them when opening up. I'm invariably on the hoods when on drop bars so again naturally in position to grab a handful of brake immediately.
Yeah on levers in traffic because they get used alot and close following cars at speed otherwise no, I find you can nip the skin on the side of your hand if you hit a bump with your hands on them.
Dave 123
No.
Neither do I ride the brakes when driving.
I'd like to think I have an awareness of what's around me, and anticipating road situations.
I can't control what others around me do, I just trust myself.
It goes wrong sometimes, but so does anything!
Lincov
Lincov
Coventry
Cheers guys, I won't change anything then. I definitely don't look behind every 8-10 seconds either!
GC
I dont always when conditions allow me to alter my riding position but its default for me to cover the brake levers. What has changed since my bike set up I was puting a couple of fingers behind the shifters and too but my recent bike fit has my hands further up the levers and there's less space behind.
glasgowcyclist
Scotland
It's a habit that began many, many years ago when I started riding motorbikes, then reinforced when I started mountain-biking.
My commuter uses gripshifts so my hand position is thumb and forefinger around the shifter and middle two fingers covering the brake, pinky round the grip. It's intuitive and comfortable for me.
Riders with different bars, shifters and brake lever setups may not find it so.
GC
endoman
Chesterfield
depends where you ride. I can ride from home for 30 minutes and often never come across a car. When I commute and get into busier areas then yes, I have the ability to stop when needed.
Linford
If there are obvious potential hazards like riding in slow moving traffic, then cover them, if not, then just on the hoods.
Cover both brake and clutch on the motorbike. Things happen a lot faster a lot quicker on these so need to be prepared to respond withou having to re arrange my fingers. Riding on the hoods is only a small reach to the brake either way on the roadie.
