Vapin' Joe
Formerly known as Smokin Joe
- Bare headed cyclist, Smoker
Calipers are designed for front brake on the left, it gives a smoother and more natural cable run.
it depends on the calliper. Mine are centre pull so it makes no difference which side the lever is on. I keep my front brake on the right because that's where it's been in my 40 years of cycling... and i aint gonna change it now.Calipers are designed for front brake on the left, it gives a smoother and more natural cable run.
It's perfectly possible to get used to both setups. One of our tandems has rear brake on the right - I have absolutely no problem changing between that and all my other bikes, which are set up like most British bikes.
I've ridden motorcycles while I've had bikes with a left front brake. No problem at all as the feel of both machines is so different there is no confusion.that's encouraging me to swap mine round, despite some reticence. Would at least allow me to signal right for two tricky junctions on my ride home.
But I'm also thinking about buying a motorcycle after a 20 year gap - so that's another reason not to.
I hired a bike years ago in Menorca that had the brakes connected arse about face.
I nearly face planted the road numerous times that day
Stupid foreigners!![]()
Same here - I've used right-front, left-back for my whole life, and would have trouble getting used to the reverse setup. Right-front, left-back is also the standard in Australia, as far as I can tell....
it depends on the calliper. Mine are centre pull so it makes no difference which side the lever is on. I keep my front brake on the right because that's where it's been in my 40 years of cycling... and i aint gonna change it now.![]()
My front brakes are on the left on my bicycle but I never really thought about it being opposite of the front brakes of motorcycles. I never knew bicycle front was on the right in the UK either.As an ex-motorcyclist front brake on the right is the way I also like on a bicycle but getting them the other way around is not a problem for me !!!!!!!!!!!!!!!!!!!!!!!!!!!!
