Saddle adjustment thingy?
Glasgow44
raleighnut
Are you sure they didn't mean Torque Wrench ?
  • Like
Reactions: C R
Cycleops
Accra, Ghana
You could use a multi tool or a regular Allen key as long as you are careful. I should contact your supplying dealer to confirm.
  • Like
Reactions: C R
boydj
Paisley
If you have a carbon frame, then a decent torque wrench is worth having, e.g. https://www.wiggle.co.uk/lifeline-x-tools-essential-torque-wrench-set/ . Make sure it is cycling specific.
As Fossy says above, though, you can tighten without a torque wrench as long as you don't use brute force. Tight enough to stop things moving and no more. If you have a carbon seat-post, then applying some carbon paste means you can get away with a little less torque.
derrick
Nigelnightmare
Seems strange, two practically identical fixings in similar materials with different torque settings.
I mean 7nm is 40% higher than 5nm!
G
Glasgow44
Hi guys
Me again! is this what I should be using:
one of my bikes is 5nm and the other is 7nm. Can I just double check because I’m not entirely sure – when it says 7nm for example, do you set the torque wrench to 7nm and twist until it stops – is that how these things work?
Thanks in advance for your help and advice
Threevok
Growing old disgracefully
South Wales
It will click (like a ratchet) and not tighten any further, when it reaches the correct torque - as per your setting
Go under. I'd set a little under. I've got the Planet X one.
You'll probably stop before the torque setting kicks in, but that does depend upon your mechanical sympathy.
G
Glasgow44
Thanks. If possible - could you send me a link for the one you have from Planet X - thanks
