Zippy
- Camborne, Cornwall
I am servicing my rear wheel tonight and some ideas, queries and posers are popping up as I go, so I thought I would share them with y'all.
When rethreading the cones, spacers and locking nuts (quick release), I guess I leave the same amount of threaded spindle sticking out of both sides so the wheel sits balanced in the frame right? I have about 6mm on both sides.
How tight does my wheel need to sit on the cones? This is quite a cheap wheel, so I guess I don;t expect miracles, but when the cones are snug I am getting a dissapointing grabbing feeling when I turn the wheel; but if I loosen the cones off a bit the rotation is beeter but there's too much play on the spindle. It could also be that the metal dust disc (non drive side) is grabbing the hub slightly and it is not the cones at all.
I'm sure there's more and I'll keep you posted, but teatime has just been called ...
